Let's talk about the BIG 2
Old May 31, 2016 | 09:27 PM
FetzerValve's Avatar
I bought just the manifold from Kyle @ KB racing and built the rest of my kit myself. His manifold, while not being cast, is quite robust and a little bit cheaper than the Trick mani. It fit perfectly and even came with a v-band flange and clamp for the crossover pipe. I'd buy it again. He also responds to my PMs relatively quickly, although I've always heard that Trick is extremely quick to respond.
Old May 31, 2016 | 09:35 PM
mdwatts11's Avatar
Originally Posted by 1CAMWNDR
Fixed that for you...LOL
And I agree with the others. There is nothing really between them.
Ha! Thanks. I was typing that while in a conversation with someone! Should have double checked.
Old Jun 1, 2016 | 12:57 AM
Jetn3's Avatar
Originally Posted by MrHorsepowerLSx
I had an STS kit years ago, it was "ok" but I would never buy another or use one if it was given to me. I'm hooked on the whistle that's for sure and boost feels great, but I had a bad experiences with my STS kit, so hence the reason that I brought up this post
I went from STS to Trick front mount. I was going with a KB kit at first, but at the time he stop building kits for a while. I'm very happy with my Trick kit but like how the KB downpipe has a v band to make install easier. Trick has a one piece downpipe that takes time to slide in place and without the v band that's one less exhaust leak.
I still have turbine whistle out the tailpipe too. Here's a video.
Has a pt7675cea, 3" downpipe to 3.5" pipe to 4" corsa diesel muffler and tailpipe exits behind pass tire. Also has an exhaust cutout right after the downpipe.
Here it is with the cutout open
With and without muffler turbine whistle still can be heard. Good luck with your choice.
Old Jun 1, 2016 | 01:39 AM
Jake75's Avatar
Originally Posted by Choda
I do not know what the other guys offer but I know Trick comes as a complete package. The tap and drill for the pan, the feed and drain hoses and fittings, the heat protector wrap, the cast manifold, the constant drive to enhance the kits and constantly improving something that is already proven to be amazing, the o ring flanges, the short IC charge pipes, inter cooler flow, #s of install threads with reviews and support, his customer support is bar none. He answers texts better than my best friends and family. Truck Tech just highlighted his kit also.
same experience i have received from Rick at trick.
X2 for the recommendation
Old Jun 1, 2016 | 05:26 AM
MrHorsepowerLSx's Avatar
11 Second Club
I have always liked the design of the trick products and have always considered using the company first before others out there (a), now hearing more of this feedback is very reassuring(b) I like the fact that the company is now getting TV air time (c) these things are all helping me to start Putting some eggs in a basket for a decision. And like the OP stated how about comparison with the DP's would the V-Band pipe be easier or would you rather just slip it in
Old Jun 1, 2016 | 07:56 AM
Choda's Avatar
My DP sides in from the Top or bottom. The turbo side is always v band. Im not sure what the question is?
Are other brands two piece downpipes? For my 3 inch, it would be redundant. There is plenty of room and aligns with everything. Maybe 4 or even 5 inch would be nice with a v band in the middle but thats a serious turbo and combo for that size dp.
Old Jun 1, 2016 | 08:26 AM
11 Second Club
I know that the turbo is always a v band, I was asking wild you rather "bolt"
Up the crossover pipe to the pass side manifold or have a v band connection. And yes if there is a 2 piece dp anywhere, would you rather it be slip fit or v band. Pardon my confusion
Old Jun 1, 2016 | 03:35 PM
GMCtrk's Avatar
never understood the slip fit on the downpipe. Once you crank down the clamp on the slip fit it's not coming apart again. You're left with a 1 pc downpipe. V band is superior IMO
Old Jun 2, 2016 | 02:06 AM
WICK3DxGATA's Avatar
Originally Posted by DieselNuts
Just how bad is the On3 customer service?
i have an on3 kit hope to be able to fire up the truck this weekend. but my customer service from on3 hasnt been bad but it hasnt been the best ive ever dealt with. they have responded to any question or problems i have had just not always the most timely response but it was never to long of a wait.
the kit is very nice for my first turbo kit, it has fit very well and have not had to do any modifications to make it fit.
Old Jun 2, 2016 | 04:01 AM
foose04's Avatar
Kyle at KB will go out of his way to make things right and has treated me great from day one. I've had great results with his stuff (hot and cold pipes) to include my current 990HP build. I've also talked with trick and was happy with the service I received. You can't go wrong either way but my vote is with Kyle only because his stuff is under my hood and works.
