Larger Cooler for my maggie, suggestions?
Old Jun 13, 2010 | 11:56 AM
  #31
fastnblu's Avatar
Originally Posted by EVILGMC
you should look into a larger or even an additional heat exchanger. what are you using for coolant in your intercooler system? i know a tank guy who will make you a custom tank that will mount to the aux battery tray. pm me for an email address. he can make anything you want
https://www.performancetrucks.net/fo...d.php?t=461042
...i use one bottle of water wetter, DI water and 10% dexcool. 3 gallon tank and a large heat exchanger. the heat exchanger size is in my opinion the most important. ...
...my IATs were max of 117• with the 2300 and 80• outside at wot.
i am using the heat exchanger for the GMT900s
Do u have the GMT900 HX dimensions handy?
Pat, where do ya get DI (I assume deionized) water from?
Prime Power uses antifreeze & some water wetter. Anything better, but if u live in a colder climate?
Originally Posted by 1Bear
One of the 24x12x1 or even a 26x7x2 if the space is limited from Frozen Boost for around 150 bucks doesn’t seem too bad. I can’t speak to the quality of one of their units, but they look as if they may be decent. I think I recall a member using one from them.
Who?
Prime Power, looking for more of a permanant solution like a Chiller Killer sounded good but price & running A/C all the time didn't? If u put biggest cooler (that 3 1/2" depth one on), what if it doesn't cool enuff for you, & u end up buying a KC anyway?
I considered the idea Most Hated said, how bout a bigger tank in the back that u can fill with lots of ice? But w/. a petcock to drain when it turns to water &/or gets too hot.
Originally Posted by AKlowriderZ71
Roger Vinci has Trucker cams on the shelf, as of a couple weeks ago. I really like mine, very good bottom end when not in boost BTW, and way better in boost.
If u already have Trucker, why would u know that?
caddy03pimpin, got pics of tank in rear & Mezeire pump running the big Maggie HX & a 30x12x4 intercooler up front? U said it's hard to fight these IATs, but are u Radix or TVS? Any meth results yet? I thought 2.8", not the 2.4" pulley was smallest on a 112 w/o OD'g unit?
Originally Posted by RibeiroBJJ
I had the Fluidyne Ford lightning heat exchanger with two 7" fans behind my bumper on my SSS with a Maggie..I also had a 1 gal fuel cell used as a ice box in the orig battery location ..with ice I would see 5-10 degrees below ambient..
Ribeiro, any pics of that? Interesting to read different ways guys go about tackling this problem. brobradh77 & others are all battling the same issues... trever1t, Magnuson said V- HX is 28x14x1.
Old Jun 13, 2010 | 01:18 PM
  #32
trever1t's Avatar
2nd fastest 5.3 ECSB
yeah Tom, that's what I thought.
Old Jun 13, 2010 | 01:24 PM
  #33
unique 04's Avatar
This one has been working good for me so far also from frozen boost with fans
Gadgetized
Oct 22, 2015 09:06 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
DrX
Sep 29, 2015 04:31 AM
Slammed silverado
Sep 28, 2015 06:14 PM
sTNT971
Sep 26, 2015 04:22 PM
