Larger Cooler for my maggie, suggestions?
#31
you should look into a larger or even an additional heat exchanger. what are you using for coolant in your intercooler system? i know a tank guy who will make you a custom tank that will mount to the aux battery tray. pm me for an email address. he can make anything you want
https://www.performancetrucks.net/fo...d.php?t=461042
...i use one bottle of water wetter, DI water and 10% dexcool. 3 gallon tank and a large heat exchanger. the heat exchanger size is in my opinion the most important. ...
...my IATs were max of 117• with the 2300 and 80• outside at wot.
i am using the heat exchanger for the GMT900s
Pat, where do ya get DI (I assume deionized) water from?
Prime Power uses antifreeze & some water wetter. Anything better, but if u live in a colder climate?
Prime Power, looking for more of a permanant solution like a Chiller Killer sounded good but price & running A/C all the time didn't? If u put biggest cooler (that 3 1/2" depth one on), what if it doesn't cool enuff for you, & u end up buying a KC anyway?
I considered the idea Most Hated said, how bout a bigger tank in the back that u can fill with lots of ice? But w/. a petcock to drain when it turns to water &/or gets too hot.
caddy03pimpin, got pics of tank in rear & Mezeire pump running the big Maggie HX & a 30x12x4 intercooler up front? U said it's hard to fight these IATs, but are u Radix or TVS? Any meth results yet? I thought 2.8", not the 2.4" pulley was smallest on a 112 w/o OD'g unit?
Ribeiro, any pics of that? Interesting to read different ways guys go about tackling this problem. brobradh77 & others are all battling the same issues... trever1t, Magnuson said V- HX is 28x14x1.
DrX
Sep 29, 2015 04:31 AM
