Larger Cooler for my maggie, suggestions?
Old May 31, 2010 | 08:42 AM
TurboGibbs's Avatar
Here is something I did back in the day with good results. Not exactly professional quality but functional.
https://www.performancetrucks.net/fo...heat+exchanger
Old May 31, 2010 | 11:09 AM
brobradh77's Avatar
Cool write up...My IAT' reach 170's with ease here in TX
Old May 31, 2010 | 11:47 AM
EVILGMC's Avatar
my IATs were max of 117• with the 2300 and 80• outside at wot.
i am using the heat exchanger for the GMT900s
Old Jun 3, 2010 | 07:39 PM
Prime Power's Avatar
Thinking about adding a cam in there. Which one would you guys recommend to compliment my magnacharger?
Old Jun 3, 2010 | 07:40 PM
EVILGMC's Avatar
lingenfelter gt 2-3 is very popular.
Old Jun 3, 2010 | 08:03 PM
Quick response. How much HP gain do you think I would see? Worth the effort? Also Vinci is good too right?
Old Jun 3, 2010 | 09:21 PM
Avalanche2002's Avatar
Check my siggy. I'm very happy with it once I got the tuning tweaked. Note I've got a 2600 stall and 4.10 gears, which helps considerably with the launch. It's a pretty good combo with the stock heads.
Old Jun 3, 2010 | 09:38 PM
Atomic's Avatar
I have a gauge for that
Old Jun 3, 2010 | 10:40 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Roger Vinci has Trucker cams on the shelf, as of a couple weeks ago. I really like mine, very good bottom end when not in boost BTW, and way better in boost.
Old Jun 4, 2010 | 01:53 PM
blownss06's Avatar
Turbogibs, how did that Jegs radiator work out. Did it maintain lower iat while crusing and at wot. Also did you keep the stock bosch pump.
