L9h twin turbo Escalade ESV build
Old Jun 10, 2021 | 12:44 PM
Sharty_McQueef's Avatar
Default L9h twin turbo Escalade ESV build
Hey guys,
been lurking for a couple years here and there but finally in a position to contribute a bit so I figured I’d introduce my project.
I’m just getting started putting twins on an 09 Escalade ESV awd. The plan is to run with the factory flex fuel pump and injectors at first and get a good baseline and then from there upgrade turbos and fuel system and likely a 4l80 swap around the same time.
At the moment the turbos going on it are t04e turbos which I know are small but should be a bit of fun.
Compressor:
Trim:
44
Inducer Diameter:50.5 mm
Exducer Diameter:76 mm
A/R:0.5
Turbine
Trim:73
Inducer Diameter:
65.5 mm
Exducer Diameter:55.9 mm
A/R:0.63
Anyways, I’ve got a new trans cooler in, plumbed the oil feed lines and have tuned the trans to a satisfactory point on HPT so far. Within the next couple weeks I’ll knock out progress on the rest of the hardware install before getting into the engine tuning.
Here’s a couple pics of the old girl:
Old Jun 10, 2021 | 12:50 PM
wretched73's Avatar
Sweet, that will be a fun ride. Love fast SUVs
Old Jun 13, 2021 | 12:20 PM
Thanks, I’m looking forward to it!
Old Jun 25, 2021 | 04:39 PM
Tig's Avatar
Tig
Definitely going to be fun ride. Lookin forward to your updates.
Old Jun 27, 2021 | 07:17 AM
smokinlmm's Avatar
Nice, should be a blast to DD! What trans is in it currently?
77x
Oct 9, 2022 01:27 AM
B00sted2007
Jun 3, 2021 01:24 AM
release2063
Dec 10, 2019 02:31 PM
Superman956
Sep 5, 2019 02:05 PM
