l92 heads
Old Jan 18, 2010 | 11:44 PM
Most Hated's Avatar
Default l92 heads
has anyone used an lq4 with l92 heads plus boost cuz i think im gonna use them just wanted to know if anybody had done it before with boost and how did it work ?
Old Jan 19, 2010 | 08:40 AM
skeet's Avatar
cant recall anyone doing it, but i dont see why it wouldnt help you, cause of the flow of the head, youre procharged right? whats your cr right now?
Old Jan 19, 2010 | 02:01 PM
old motorhead's Avatar
Would an LS3 qualify? I'm real happy with mine, but it has that TVS2300 thing on top. It makes good power on mild boost. If the LQ4 in my truck ever scatters, I'll redo it with l92/ls3 heads. They might lose a little low end with a centri blower. The TVS doesn't allow that "lack of low end" problem.
Old Jan 19, 2010 | 02:17 PM
pewterliftedz's Avatar
ill be watchin this, im curious of the CR of a LQ4/L92
Old Jan 19, 2010 | 11:31 PM
Most Hated's Avatar
itl be like the new vortec max 6.0 i think cuz they have dish pistons too so ill have like a 9.6 l92 are 70 cc heads
Old Jan 20, 2010 | 08:04 AM
OnyxSilveradoSS's Avatar
I have a Lq9 W/l92 heads and my compression is around 10.5/10.8-1
people have said that the L92 head has a thin deck which might be an issue with boost. But I bet you would blow a stock piston b4 you would lift a head
Old Jan 20, 2010 | 10:00 AM
lablackbeast's Avatar
doesn't know what quit means
what you mean by thin deck...??
Old Jan 20, 2010 | 11:17 AM
the casting of the heads that mates to the block is 'thin' possibly causing it to lift underboost. This is why the LS9 uses different heads, plus some other tricks but for the most part I think you would be fine with OE heads + Boost if you have OE pistons and keep the boost where they will not explode. but if you go past 12-15 PSI w/o alot of meth, then I bet you will lift or destroy your pistons...unless you are TJ from MI who can queeze some sick #'s out of turbo's with OE parts
Old Jan 20, 2010 | 11:32 AM
Matt G6007's Avatar
the l92 heads are 68 cc and when they r on a lq4 its right at 10 to 1 cr
Old Jan 20, 2010 | 12:28 PM
skeet's Avatar
dunno about the l92 heads but i run the ls3 heads, the deck thickness if not mistaken is 7/16 which standard heads are 1/2. milling the heads lets say .030 with a 040 gasket on a lq4 should get you to a round 10.5.1 or close to it, what was mentioned to me anyway
