Kenne Bell Boost a Pump
Old Apr 26, 2008 | 02:34 PM
moregrip's Avatar
what a rush!
Default Kenne Bell Boost a Pump
How did you wire yours up?
my intention is to wire this non-progressive, as soon as it see's 3psi, full voltage will be applied
I need to tackle this ASAP. Looks like I need a power wire, a ground wire, hook up the wires to the hobbs switch.
What did you do with the RCA jack and the remaining wires?
Old Apr 26, 2008 | 02:36 PM
BlownChevy's Avatar
blownerator
25 Year Member
Throw them away. Twist the two wires that go into the KB BAP together.
Old Apr 26, 2008 | 02:38 PM
moregrip's Avatar
what a rush!
as in connect them together electrically?
Old Apr 26, 2008 | 02:39 PM
BlownChevy's Avatar
blownerator
25 Year Member
Yeah, the two that come out of the KB BAP, (black and white I believe) Get connected together. Lemme go check mine. BRB
Old Apr 26, 2008 | 02:41 PM
moregrip's Avatar
what a rush!
roger, thanks. also, where is the most convenient place to tap the fuel pump power wire?
Old Apr 26, 2008 | 02:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
wire "C" gets cut and tied together, wire "S" goes to the hobbs switch. Fuel pump wire is the same wire you trigger your I/C pump off under the fuse box.
Old Apr 26, 2008 | 02:47 PM
moregrip's Avatar
what a rush!
oh so easy.............so the wire tap used for the I/C pump, that is the same wire I would use to go to the KB BAP? That will work out rather well as I should be able to splice all three nice and clean like; however, I suppose I better put tha KB BAP downstream of the I/C pump(LOL) or I'll have one heck of a fast flowing I/C system
Old Apr 26, 2008 | 02:56 PM
BlownChevy's Avatar
blownerator
25 Year Member
10-4
Old Apr 26, 2008 | 05:10 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
huh? no MV for you?
Old Apr 26, 2008 | 05:28 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by trever1t
huh? no MV for you?
left over from the turbo system.
