Kenne Bell Boost a Pump
How did you wire yours up?
my intention is to wire this non-progressive, as soon as it see's 3psi, full voltage will be applied
I need to tackle this ASAP. Looks like I need a power wire, a ground wire, hook up the wires to the hobbs switch.
What did you do with the RCA jack and the remaining wires?
oh so easy.............so the wire tap used for the I/C pump, that is the same wire I would use to go to the KB BAP? That will work out rather well as I should be able to splice all three nice and clean like; however, I suppose I better put tha KB BAP downstream of the I/C pump(LOL) or I'll have one heck of a fast flowing I/C system
