The Kenne Bell 2.8L after 2 weeks of Driving.....
Old 12-13-2006, 03:19 PM
vanillagorilla's Avatar
Also is your IC A2A or A2W?
Old 12-13-2006, 04:59 PM
Originally Posted by Decoy383
did u get the intercooler that came with the kit or is there a after market kit that will fit?
This is an aftermarket intercooler from trturbo.
Old 12-13-2006, 05:06 PM
Originally Posted by BlownChevy
are your sub 100 temps under boost, or just cruise?
In my previous setup with the 2.2L, under boost and cruise, the IAT's were usually under 110 on the hottest day of the year when ambient was around 90-95. Attached is a plot of the 2.2L under boost at 75 ambient. When it gets into boost the IAT's actually drop. If I sit in traffic with the fan off for 20 minutes, the IAT's will heat soak as high as 135. Turning on the Fan usually takes them down to 100 even in traffic. I will record some logs with the new set up soon. The scan gauges show at least 20 to 25 degrees improvement.
Old 12-13-2006, 05:55 PM
Revolutionary's Avatar
Those are some very impressive numbers for your IAT's Def love the air to air heat exchange.. That has to be pretty good Intercooler core do you have any other specs on it? I would also like to check out your setup do you have any other pics anywhere on the site?
Thanks-
Old 12-13-2006, 05:57 PM
03sierraslt's Avatar
I have the same intercooler setup, if you click on the link in my sig you will find more pics.
V- Trying to keep you from having to dig up pics.
Old 12-13-2006, 06:23 PM
That is a sweet setup thanks for the info!
Old 12-13-2006, 08:28 PM
Decoy383's Avatar
what is the web link so I can purchase it? Also have any of you guys blown a piston ring or rod yet? I read some where that the stock ones only hold up to 500hp.
Old 12-13-2006, 08:54 PM
What are you looking to purchase? If you are refering to the KB supercharger then its www.kennebell.net
Old 12-13-2006, 09:14 PM
04Denali's Avatar
It seems to me the A2A intercooler is more efficient than the A2W. To bad you cand have A2A with a manifold mounted SC
Mark
Old 12-13-2006, 10:16 PM
Decoy383's Avatar
How does that intercooler for KB side mount intercooler work? How is connect to the manifold and SC?
Quick Reply: The Kenne Bell 2.8L after 2 weeks of Driving.....
