Kenne Bell 2.8 vs. Eaton 122
Old Jun 17, 2007 | 09:42 PM
yurs78's Avatar
Default Kenne Bell 2.8 vs. Eaton 122
KENNE BELL 2.8L vs EATON 122 (2.0L) SAME 3" PULLEY
How does the latest Eaton 122 (2.0L) Roots type, which is even larger than the Eaton 112 (1.85L), compare to the Kenne Bell 2.8L Twin Screw kit with the same 3” pulley, custom tune (23° 11.5 AFR), stock inlet systems, etc? To make 125HP at the same supercharger rpm, there must be something better about the Twin Screw. The Kenne Bell 2.6 and 2.8 are simply larger displacement more efficient superchargers that produce higher air flow, boost and HP - and they consume LESS engine HP to operate.
RESULTS: MORE HP, LOWER PARASITIC LOSS, HIGHER BOOST, LOWER TEMPS
Note: This test was performed on the ‘07 Shelby Cobra as it is the only factory produced vehicle with the 122. At 23 psi, the 100% stock Shelby made 801HP!
I hope the this posts up well. I found this at the bottom of the Corvette section on the Kenne Bell web sight. I though it was a pretty interesting test. I also think it's crazy that it made 801HP at 23 psi of boost! (I'm almost positive that's to the wheels)
Enjoy.
Old Jun 17, 2007 | 09:46 PM
yurs78's Avatar
Sorry, I don't know how to get the graph up. I'm retarded
Here's the link, it's at the bottom of the page.
NSL
Old Jun 17, 2007 | 10:40 PM
BlownChevy's Avatar
blownerator
25 Year Member
Like you said in your post....The screw was a bigger blower.....like comparing apples to oranges. You can enjoy the fun for now, once the new **** hits the streets....KB and Whipple might need to spend some money on R&D for a new blower.
Just my opinion of course.
Old Jun 18, 2007 | 08:54 AM
ZO6Ted's Avatar
As I understand, it was to the wheels but on race gas. Still awesome! Factory stock with a blower change, why does Chevy make it so hard for us.
Old Jun 18, 2007 | 09:04 AM
dan96z71's Avatar
Hey Brian, you back to running the radix or still running the sts....you probably have said in another post, but I haven't seen it.
Old Jun 18, 2007 | 09:17 AM
BlownChevy's Avatar
blownerator
25 Year Member
Still running the STS, waiting for my TVS
Old Jun 18, 2007 | 03:54 PM
Sierra1320's Avatar
Once the Eaton TVS hits it's gonna blow everything out of the water
Old Jun 18, 2007 | 04:07 PM
nightrunner's Avatar
Mr. Obvious
the twin screw is simply more efficient no matter what size either is than any roots or roots hybrid on the market currently (excluding TVS)
Go5.3tt06
25
Sep 4, 2016 10:25 AM
moregrip
Jul 26, 2016 11:21 AM
FlyingLow
Nov 24, 2015 10:05 AM
Chavette
Oct 28, 2015 07:33 PM
pewter00
Sep 13, 2015 11:14 AM
