Kenne Bell 2.4L Kit...
#23
#26
I'm calling BS on the early 08
If they do come out in early 08 I'll buy one, unless its available sooner down under.
The KB blowers have been making more power than Maggie's with the Ford guys for sometime. They have done it with more boost and lower IAT's. I wouldn't expect someone who pimps for Magnuson to give an unbiased opinion either.
#27
I just a ran a 13.67 2 97.5 mph last night with my H2 running a KB 2.8 on a 402. I had to lift at the 2-3 shift for a moment becaust I ran slightly lean, but I got back in in it for the rest of 3rd gear. Had the run been clean I'd be posting a 13.5@100 mph from this combo. IAT's are not reason to worry about this combo. It makes WAY more power than the Magnuson offerings, but you do have to put more work into it. That comes with the territory when you make a lot of power.
For the record, the best the maggie ever did on my truck was a 13.86 with a 70-75 wet shot of nitrous on the H2 with a stock LQ4, LPE GT 2-3 cam, no cats. The KB 2.8 (forged 402, AFR 225's, Baby turbo cam, long tubes no cats) just did a 13.67 at 11 psi and wasn't even sweating yet. The alcohol injection system didn't even run on that pass.
Yes the blower case gets hotter but does not cause knock retard the same way the other one did. Both blower measure "IATS" off the Blower case. Not the most accurate form of measurement but it works okay. Better for the PCM to think its getting air temps that are hotter than reality than it is cooler than reality.
Once again, the Kenne Bell makes the best power of the available intake mounted superchargers. If a little extra work to develop your install is a detterent, then its not for you. The more power something can make the less plug and play it all is.
The TVS remains to be seen, but continues to be hyped. I hope its a great blower when it finally gets to market.
#28
i got the older style kenne bell twin screw not sure if it is the 2.4 but it is not intercooled but my 2002 tahoe z71 4x4 5.3 flex fuel ran a 14.7 at the track and all i have is 45lbs injectors cat back magnaflow and a kenne bell supercharger pushing 8 to 9 pounds of boost. and my truck has 20 inch ss wheels
#29
[/SIZE]
Call it what you will.....been there, tested that. FYI, I have a few TVS 1900's in pre-production that I could sell ya......now put your money where your mouth is
As for your BS meter:
