kbracing96 front mount conversion COMPLETE!
#22
and as stated above dangerous things happen from boredom
#23
High on diesel fumes
I don't know for sure. The manifold design should be a little more efficient due to the position and location of the runners. I am also going with a 3.5" downpipe as opposed to the original 3" one, so there should be a little bit less restriction after the turbo. Because of the new position of the turbo, I was able to get rid of a 180* bend in the cold side piping too, and removed about 3 silicone couplers in the process. That should prove to be much less restrictive as well. Whether or not those make a noticeable different remains to be seen.
#26
Since you all ready have everything apart you might want to look at the passenger side exhaust manifold. I noticed that mine necked down to 2.25 at the flange, and the ports are smaller than the gasket and head opening by 1/8in on the top and bottom. Maybe mine is just a bad casting, but given your cubes and amount of boost potentional it might be worth breaking out the dremel tool and gasket matching the ports and opening up the exit flange to 2.5in...
#27
If you're talking about the stock driver's side manifold, that's probably a good idea. I'll check it out.
#28
All the black stuff is where the manifold is smaller than the port and gasket, I am going to grind it all away...
Sorry for the blurry pic, but as you can see it is smaller than 2.5... see all the black stuff, that shows where it is smaller than the flange...
#30
Chris, I recommend adding a 1/8 NPT port on the passenger manifold if you are interested in knowing what your exhaust pressures are. I did that to my manifold... but plugged it for future use as my lil ole 5.3 isn't pushing enough air through my for me to be worried about it now.
Manifold looks good
Bill
Manifold looks good
Bill
