Just to be sure quick yes or no PLEASE
Old Aug 18, 2008 | 06:19 PM
Mangled03gmc's Avatar
Baltimore Whore
Default Just to be sure quick yes or no PLEASE
I searched and just want to make sure, it will be fine if I tap the line from the intake to the brake booster for my boost gauge. Now that line is also tapped for my bypass valve, I still should be ok having it tapped 2 times correct. Other then that I would have to tap the intake...
Just want to be sure.. Thanks guys
John
Old Aug 18, 2008 | 06:34 PM
thunder550's Avatar
High on diesel fumes
Yes, you should be fine.
Old Aug 18, 2008 | 06:50 PM
Baltimore Whore
Ok well I axed that idea, broke into the lil nipple on the pass side. I didn't want to have to many breaks in the brake booster line.. Thanks Thunder..
John
Old Aug 18, 2008 | 06:52 PM
thunder550's Avatar
That will work too.
You just wanted to have an excuse to use the phrase "I broke into the lil nipple".
Old Aug 18, 2008 | 07:00 PM
Baltimore Whore
NO SIR not me
John
Old Aug 18, 2008 | 08:36 PM
03sierraslt's Avatar
Mine is tapped from the lil nipple too..... haha
Old Aug 18, 2008 | 11:14 PM
Superado's Avatar
11 Second Truck Club
I have a distribution block mounted inline on my booster vacuum hose that is currently providing a vacuum source for by-pass valve, boost gauge, tranny vac mod and MSD FPB...still have one free port that is capped off...
Old Aug 18, 2008 | 11:16 PM
Baltimore Whore
Yah I may do some thing sim to that down the road. So far it is all working great, but only seeing 6lbs from that 3.4 pulley, I need to down size now, but just glad it is all working...
John
Old Aug 18, 2008 | 11:33 PM
Superado's Avatar
this is a P1 or D1?
either way you should be seeing more than 6 #'s w/ a 3.40" pulley...
I did 10+ #'s w/ a P1SC on a stock 5.3 w/ a 4.0"
doing the same now on the new lower compression motor w/ a 3.40"
I think ranwalk is doing 12 #'s with a 4.0" w/ a D1SC on a 408
Old Aug 18, 2008 | 11:37 PM
Baltimore Whore
This is a P1, but would the 112lsa on the cam bleed off boost?
John
