Just to be sure quick yes or no PLEASE
I searched and just want to make sure, it will be fine if I tap the line from the intake to the brake booster for my boost gauge. Now that line is also tapped for my bypass valve, I still should be ok having it tapped 2 times correct. Other then that I would have to tap the intake...
Just want to be sure.. Thanks guys
John
John
Ok well I axed that idea, broke into the lil nipple on the pass side. I didn't want to have to many breaks in the brake booster line.. Thanks Thunder..
John
John
I have a distribution block mounted inline on my booster vacuum hose that is currently providing a vacuum source for by-pass valve, boost gauge, tranny vac mod and MSD FPB...still have one free port that is capped off...
Yah I may do some thing sim to that down the road. So far it is all working great, but only seeing 6lbs from that 3.4 pulley, I need to down size now, but just glad it is all working...
John
John
this is a P1 or D1?
either way you should be seeing more than 6 #'s w/ a 3.40" pulley...
I did 10+ #'s w/ a P1SC on a stock 5.3 w/ a 4.0"
doing the same now on the new lower compression motor w/ a 3.40"
I think ranwalk is doing 12 #'s with a 4.0" w/ a D1SC on a 408
