Just installed GT2-3
Old Mar 23, 2008 | 10:02 PM
La Riddler's Avatar
Default Just installed GT2-3
I just finished installing the GT2-3 and 60# injectors. I was only getting 3 psi and hoped to get the full 8 psi with the cam swap but had no luck. What can it be???
Old Mar 23, 2008 | 10:03 PM
BlownChevy's Avatar
blownerator
25 Year Member
What pulley?
Old Mar 23, 2008 | 10:31 PM
La Riddler's Avatar
3.25 is for 8#, am I right?
Old Mar 23, 2008 | 10:35 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
You either have some awesome flowing heads and exhaust or your boost gauge or MAP sensor is screwey?
BlownChevy's Avatar
blownerator
25 Year Member
Should be that or more. Are you running the stock balancer?
Old Mar 23, 2008 | 10:46 PM
La Riddler's Avatar
Yes and stock heads 2. I have tried 3 different gauges and going to try the aeroforce tomorrow. I did feel better pull with this cam and haven't retuned it yet.
Old Mar 23, 2008 | 10:47 PM
BlownChevy's Avatar
blownerator
25 Year Member
If you are running the stock balancer, and it is pinned you must have some other issues going on.
Old Mar 23, 2008 | 10:54 PM
La Riddler's Avatar
could it be the by-pass?
Old Mar 23, 2008 | 10:57 PM
gao8302's Avatar
how your bypass. Is it working correct?
Old Mar 23, 2008 | 11:34 PM
La Riddler's Avatar
don't know how that works, but I can see that it can be adjusted.
