Just Another Succcessful Trick Build
Well I finally got everything done - The turbo is in and made the switch from Kennebell 2.8 to Turbonetics 7575. Im sure you folks are already aware of the differences - The supercharger was more violent causing some good torque steer at the start. The turbo his a slight delay due to lag but catches up very quickly and pulls past the charger at some point in time. I was thinking of bolting on a procharger on the other side to get out of the hole quicker - any thoughts? I would plum the charger in parallel but use a separate intercooler.
Im still thinking of how to plumb the procharger on the other side - I'll try it in parallel first with a separate blowoff so I'm not over pressuring the turbo with the supercharger
