interesting read on spark plugs for FI...
Old Sep 22, 2006 | 11:17 AM
Superado's Avatar
11 Second Truck Club
Default interesting read on spark plugs for FI...
https://ls1tech.com/forums/showthread.php?t=575354
Old Sep 22, 2006 | 02:14 PM
Superado's Avatar
another great read related to the same discussion...
http://ngksparkplugs.com/techinfo/sp...000&country=US
Old Sep 25, 2006 | 09:23 PM
Superado's Avatar
anyone run the 4554's?
Old Sep 25, 2006 | 10:09 PM
parish8's Avatar
single digit dreamer
there are a lot of diferent sugestions coming from that first thread. i have tried a few diferent plugs and never have noticed much diference other than the colder you go the rougher the idle is.
seems like the general rule of thumb is a tr6 for any boost or nitrous up to as much as 10-15psi. then switch over to the next step colder wich in a ngk is a br7ef. i suppose at some point maybe 25psi step up to an even colder plug in the tr8 heat range.
Old Sep 26, 2006 | 08:46 PM
cablebandit's Avatar
9 Second Club
tr8s are rockin and rollin so far...no wot pulls yet and it is idleing fine so far. I will pull one in the morning Al and see how it looks
Old Sep 28, 2006 | 12:11 PM
Superado's Avatar
As I understand it, in our FI applications, it is not so much that the 4554 is a colder plug than a TR6...it is the projection of the tip being less than that of a TR6 that is desirable...I will add pics of them side by side after lunch...
Old Sep 28, 2006 | 01:54 PM
Superado's Avatar
not very clear picture, but the difference is very clear...
Old Oct 2, 2006 | 07:36 AM
Superado's Avatar
no thoughts on the projected tip?
Old Oct 3, 2006 | 12:39 AM
I've been using the new ZEX plug for FI and seems to be real good. Smooth idle and supposed to be designed to prevent kr.
Old Oct 4, 2006 | 01:56 AM
rgcbshrty's Avatar
I agree. A TR6 can work well up to 14psi on a Lightning and even higher boost. For safety sake I wouldn't want to go past 14psi though.
Regarding insulator projection...If you want to go inbetween the TR6 and br7ef a stock Lightning plug or TR7ix would do nicely.
Fast86z
Aug 23, 2015 12:35 AM
rojeho
Aug 8, 2015 07:20 PM
wheeliE-maxx
Jul 19, 2015 05:37 PM
sTNT971
Jul 16, 2015 12:39 PM
