intercooler mounting??
Just read about your chiller. I like that ideal. How would it work if you used the ac to surround the tubes on a a2a. make a box over the tubes and charge it.
I browse around over there.. A supporting vender over there which is less than 30 miles from the shop has had a couple pm's from me..havent gave me the time of day. I guess it becos i am working on a C4 vette which most think is the lowest of the low in vettes. lmfao. I work on vettes ever day and some are the highest priced older cars around. I install LS7 and others on a daily base. I respect the ppl who give me the time of day and have got it from ppl here.
here is a link to what i have to work with. its an older car.. the only difference is that my radiator is laid back more.
http://forums.corvetteforum.com/c4-t...r-in-a-c4.html
the pulley setup i am using is from work which gives me a lot more room to the sides. the top pix the motor is setting in a mid 70's frame. the 2nd is setting in one of our built frames
There is a company out there that has an air to air intercooler with extra channels for co2 to help the cooling down. You could hook the ac through it. I really like the air to water set ups, you can get some really low intake temps. Takes up less room and less plumbing usually.
Let me know if I can help you in any way.
