Intercooler came off results.
Old May 17, 2007 | 09:19 PM
  #21
hemidup's Avatar
Originally Posted by James B.
Find a 1200HP rated intercooler and some elbows on EBay and build your own intercooler setup. That's what I did and it works amazing. IAT gets to no more than 25 degress over ambient IAT no matter where the throttle is and that with hot-air intake. I also have a very large surface are heat exchanger up front. Better to go large area and thin than small area and thick when shedding the most heat is desired.
This is the intercooler radiator on the right side:
I've been watching your build. Great work and nice setup. Clean and professional.
Old May 17, 2007 | 09:32 PM
  #22
hemidup's Avatar
Originally Posted by hemifever
You go richer because your air isn't as dense now. So basically you're getting less air, same fuel.
Don't forget your cam that you added. Remember I talked to you about overlap and superchargers? You can be losing boost based off the cam overlap (and other characteristics) and with a supercharger it's just lost. With a turbo, the turbo adds more boost automatically causing it to work harder and have a little more EGT. I was figuring you'd pick up boost from the i/c removal, and lose some based on the cam, and you'd be even.
As you know, I run the FRI 216/220 114lsa camshaft. CamMotion just got back to Denny today and recomended a custom grind of 218/222 114lsa with all the info from my motor. With those numbers, the valves are staying open longer, allowing more air and fuel to fill the cylinders efficiently. When Denny told them we lost a little boost with our new cam, they said that was a good thing. Looks like I can pulley down again.
Old May 20, 2007 | 04:36 PM
  #23
hemidup's Avatar
Originally Posted by ColtSteele
Just curious if they did anything else to it besides the intercooler. So when's th enext track date Jerry?
I'll be heading to a local 1/8 mi track next weekend for TnT. I never raced on one before in my life. My new drag radials for all four corners will be in next Tuesday. With the a/w intercooler off and less boost, the truck is really pulling hard. Less KR like before so I'll just be using straight h2o injection with non oxygenated 93. If knock shows up with the open headers and torque tubes, I'll have some methenol for back up. I'm shooting for a 12.8 a/f in 1st, 12.5 in 2nd and a 12.2 in 3rd with the POS stock Mopar PCM. I wish HP Tuners could help us Dodge guy's out.
Old May 25, 2007 | 08:21 PM
  #24
hemidup's Avatar
3rd gear is still fat. Just ran the 1/8 mi Superchips data acquistion program that put me at a 7.37@91mph. Tomorrow night will be real time numbers.
Old May 25, 2007 | 08:30 PM
  #25
SRT10KLLR's Avatar
Former Vendor
Jerry, that's smokin' for a 4x4 with no weight reduction!
Old May 25, 2007 | 08:49 PM
  #26
hemidup's Avatar
Jimmy, The Mustang intercooler that came with the GSM kit was nothing more than a huge restriction. I put a new belt on and the boost came back at 12 psi. EGT's are still happy. I maxed out your 55lb injector setup again and we're now tuning with two 48lb auxilary injector backup's.
Old May 25, 2007 | 09:27 PM
  #27
How much fuel pressure are you running and is your fuel pressure boost referenced?I think that raising your fuel pressure would be more easily controlled than adding 2 extra injectors.
Old May 26, 2007 | 07:58 AM
  #28
hemidup's Avatar
Dodge trucks are equipped with a dead head fuel system that have a constant 58-60 psi of fuel pressure at all times. With the smaller blower at 8lbs of boost at wot in 3rd, I lost about 4lbs of fuel pressure. I introduced another fuel pump inside the tank. One fuel pump runs the left bank and the other runs the right with a cross over at the fuel rails. After controlling the fuel pressure problems, I went with a larger blower and now run 12lbs of boost. If I went with 60lb injectors, MAP voltage becomes an issue at lower rpms. If HP tuners would come out with something for Dodge trucks, I could get rid of my multiple piggyback systems that I have to use to trick the stock PCM into thinking it's still running a stock engine without throwing any codes or cel's.
Old May 26, 2007 | 12:41 PM
  #29
When you say you are maxing the 55lb injectors,does that mean you are running them at a 100percent duty cycle,that would mean you are making 935 fwhp.55lb injectors @58psi should be good for 748 fwhp at a 80 percent duty cycle and 795 fwhp at a 85 percent duty cycle.That's assuming a boost referenced reguator,if it is not boost referenced you will loose about 10 psi or an amount equal to the boost you are making.With a non boost referenced reguator the supercharger would only see 48psi of fuel pressure and max the injectors at about 850 fwhp or 680 rwhp. How much power are you making?
Old May 26, 2007 | 03:11 PM
  #30
SRT10KLLR's Avatar
Former Vendor
We can't increase duty cycle to the injectors directly so we increase MAP voltage to get more fuel but we are limited to 5V so we don't max(100%) out the duty cycle. We probably are only pushing the injectors to a 80% idc. He is definately making 650+rwhp right now with his setup.
One of these days there will be HemiEdit then we will be able to tune these Hemi's right.
BTW, I get a max of 675 crank hp with a BSFC of .55, 58psi, & 80% idc. The injectors are 612cc at 58 psi(4 bar).
