intake charge temp is to high with radix
Old Jul 26, 2006 | 10:05 AM
BlownChevy's Avatar
blownerator
25 Year Member
I would highly suggest checking your intercooler pump. Sounds to me like its not working,
Old Jul 26, 2006 | 10:40 AM
onyx's Avatar
14 Second Truck Club
i was about to say, with temps that high, either your pump isnt working or you havent checked your reservoir level lately.
Old Jul 26, 2006 | 11:02 AM
dewmanshu's Avatar
Moderately Differentiated
my pump "seems" to work fine. reservoir is above the inlet/outlet levels enough. How do you test the pump working at 100%? not a smart *** question, just a question. If it's close to 100* outside I will hit 190 to 200 on the IAT's. Drop just 10* in ambient and my IAT's only get to maybe 180 on a 1/4 mile run. That's why I'd like to have the time to make a graph of my IAT's vs ambient. With me, the curve would shoot almost vertical as you pass 95* ambient.
j's, only a 3.1 pulley...You don't hear of 200* IAT's that often and when you do it's normally a mechanical issue. But i can't find anything wrong with mine, so until i get a larger hxr, I am ASSUMing mine is just due to a 2.8 pulley and hot weather, but on a 3.1 pulley-as always BC is usually on with issues. Something is more than likely a miss with a 3.1 pulley generating 210* IAT's. I still say the IAT spark is agressive, but I didn't realize we were talking about a 3.1 pulley.
Old Jul 26, 2006 | 11:43 AM
Last Call's Avatar
TOTM: January 2007
I think whoopassracer has a 3.0.
Old Jul 26, 2006 | 01:35 PM
onyx's Avatar
doesnt the pump have one "speed" setting? on?
when i fill it, i turn the truck on and have it cycle through while filling. plus since i have bags, i make sure to get the front end is high enough to the air out of the system.
Old Jul 26, 2006 | 02:18 PM
whoopassracer's Avatar
I have a 2.75pulley
Old Jul 26, 2006 | 02:28 PM
from the starting point i dont know whats the temp but at finish line im at 209 on the third pass in third gear. temp outside was 92*
Old Jul 26, 2006 | 02:51 PM
03sierraslt's Avatar
Originally Posted by Whippled 496
Wow, thats 9X% efficient....very nice. Is that in a whole 1/4 run?
almost, furthest I have had it WO with the intercooler is right when it shifts into third.
Old Jul 26, 2006 | 02:54 PM
bud8fan's Avatar
Originally Posted by krambo
In 80* heat ambient, I see 130 max at the end of the track spraying 50/50 meth through the radix. Start temps are in the 120's
In 55* ambient, I see 100-110 at the end. A better time by .25 as well
same numbers here with meth/water now....max 130*
Old Jul 26, 2006 | 03:36 PM
just check the pump and reservior it's all working good
