intake air temp. HELP
Old Jun 27, 2009 | 11:09 AM
  #21
Mort's Avatar
Originally Posted by duckysbht
When im cruising with my STS its roughly 10 above ambient. But if I stop, since I just have my exhaust dumped, sitting in traffic will create a lot of heat with the exhaust + heat of just the road.
Do you have a FMIC? None on mine and I usually see 30*F over ambient. I run meth for WOT and any boost over 5 psi and it works well at cooling the intake air.
Old Jun 27, 2009 | 04:58 PM
  #22
therock's Avatar
I have a new tune so I have been keeping and eye on it recently.
I was told by some experienced rodders at the Dyno shop my CAI was a problem on the street because it's an open under hood element, and even if it does have a token box and hood rubber seal it's really a hot air intake.
I run @ 129* cruising around in 95* heat with the stock non-modified air box. With the AIRAID CAI I run 10* hotter. So it looks like the CAI is really an HAI.
I tested by driving in the same temps on the same routes doing two back to back WOT runs through 3rd gear. Then I drove it normally until it returned to the cruising temp. Going the same distance the AIRAID didn't fully return to the cruising temp.
Corvette454l88
Sep 1, 2016 01:24 AM
GMCtrk
Dec 18, 2015 04:47 PM
The_W
Aug 18, 2015 04:57 PM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 14, 2015 02:10 AM
