Injectors size's stock or bigger?
Old Aug 17, 2010 | 09:54 PM
3DTIM's Avatar
Default Injectors size's stock or bigger?
My stock injectors are 42psi the motor is stock 5.3 Headers 2.5 exhaust no cat's 112 Maggie . Looks like mine are doing some misfiring so stay stock or go bigger for more power. Truck runs great but you know how it goes more power is always more fun.
Old Aug 17, 2010 | 10:06 PM
blue0453's Avatar
if these are stock injectors they are 28lbrs, 38lbrs for flex fuel. the 42s or the 8.1 injectors.
Old Aug 17, 2010 | 11:40 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Mostly depends on your build, and your goals. If you are not maxing out your 42 lb injectors, going bigger will not give you any more power.
Just to give you an idea, with my current setup, I shift at 6400 rpm and the injectors are at 102% duty cycle. I'm not sure how stock your setup is, or isn't, so I really don't have any way to recommend 42's or 60's. Do you have any way to datalog your IDC?
If you just have dirty/clogged injectors, a Motorvac fuel system service should correct the problem, and save you money.
Old Aug 17, 2010 | 11:55 PM
WorkTruc's Avatar
I agree with this.My injectors are at 95% with 3.0 pulley.
Old Aug 18, 2010 | 12:43 AM
3DTIM's Avatar
Thanks a lot guys. Running Lucas Injector Cleaner in the take now. Hope that will clean it out. Truck ran fine going to Louisville put gas in it there and has run like crap every since.
DrX
Jan 23, 2016 09:49 PM
maxspeed05V
Jul 19, 2015 07:08 PM
GMCtrk
Jul 17, 2015 06:39 PM
black6spdz
Jul 16, 2015 01:32 AM
jrplz
Jul 9, 2015 12:07 AM
