Improved Magnuson Tensioner
Old May 26, 2008 | 10:58 AM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by trever1t
Time for the Metco's maybe? where the best source (cheapest) for them?
if you want idlers, PM joe @ left coast. The metco's WILL NOT last, Joe has a line on some with a double row bearing that will stand up to the RPM.
I bet its your belt, got a bar of ivory soap? (god thats old school)
Old May 26, 2008 | 11:10 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Hmm, I have used the soap trick before on something else. The squeak is not belt squeal, it is a rhythmic sound that increases with rpm until it is warmed up. Never did it before!
I will give Joe a shout on the pulleys, thanks!
Old May 26, 2008 | 11:20 AM
leftcoast32's Avatar
FormerVendor
I am submitting an order for some more pulley's tomorrow. Let me know if you need some. It is a shouldered smooth idler pulley and uses the Magnuson pulley spacers.
Old May 26, 2008 | 11:35 AM
BlownChevy's Avatar
blownerator
25 Year Member
Don't you have a package with the tensioner and idlers?
Old May 26, 2008 | 11:44 AM
FormerVendor
I have a full 8 groove pulley setup that works great with the new Tension.
Old May 26, 2008 | 11:46 AM
BlownChevy's Avatar
blownerator
25 Year Member
gotchya
Old May 26, 2008 | 12:00 PM
FormerVendor
Originally Posted by BlownChevy
gotchya
The idler pulley's I have now are 76mm on the belt contact area. I may have another set made that are 95mm for the trucks. The Inlet Forward design cant run a big idler because it will contact the supercharger pulley. The trucks have enough room to run the bigger diameter pulley's.
Old May 26, 2008 | 12:10 PM
BlownChevy's Avatar
blownerator
25 Year Member
True, however I have yet to see a HUGE advantage to running a larger idler on the trucks. The style you have would work perfect.
Old May 26, 2008 | 12:23 PM
trever1t's Avatar
What about Metco 90mm double bearing pulleys?
This billet idler pulley is specifically designed for severe-duty applications, such as those running higher boost levels or aftermarket superchargers like a Whipple or a Kenne-Bell.
The pulley is machined to accept twin bearings to provide added stability and the ability to withstand excessive belt loads. The pulley is hard-coat anodized in black and includes a separate bearing dust cover and stainless steel fastener.
This pulley can be installed as a direct replacement for an OEM idler pulley or anywhere a standard Metco Motorsports idler pulley can be installed. Also available in 100mm diameter.
Old May 26, 2008 | 02:19 PM
BlownChevy's Avatar
blownerator
25 Year Member
I personally watched them fail on Joes truck.....and Devin had them fail as well.
