IATs With Meth on Radix?
Old Aug 18, 2006 | 10:43 PM
DrX's Avatar
DrX
Originally Posted by Double-L
I made some runs at Indy with the same tune and my IAT run hotter with the alky on than with it off, I tried running 50 50 and it slowed me way down, I still play with the tune and keep trying the alky but can always run faster with the alky off, Knocks just as much with alky as it does without it, I hate to take it off after I paid that much for it and holdig out hope for it one day,
What type of FI are you running? Where are you injecting the meth? Could slow you down with too much, if it is coming on too soon, or if you are not tuned optimally for the meth.
Old Aug 18, 2006 | 10:59 PM
DrX's Avatar
DrX
Originally Posted by BigBlackAv
I have a switch that i wired in so i can turn the meth off (if i leave it on, i will use 5qts in one day) and i see my base temps lowered by 15* ...w/ 97 and high humidity ambiant, i usually have 130-135 IAT's under normal driving...but w/ the meth on it is usually about 120*...i'll do a few boosted lauches w/ and w/ out to post some more numbers.
I drove out to the cottage with the meth powered up. About 90 miles. The little 2 qt tank that comes with the Snow kits just won't cut it for daily use. I don't have a switch yet but I can pop the hood and pull the fuse that I wired into the system.
Old Aug 19, 2006 | 08:33 AM
Double-L's Avatar
I am running a Magna Charger, Have the meth injecting right before the T.B., Have the meth comming on with rpms, I can change how much I run from the inside of the truck, Running about 9 lbs of boost
Old Aug 19, 2006 | 12:10 PM
Danville Performance's Avatar
Default Temps with meth...
Ok guys, the meth doesn't really help your air charge temps, for that you need to do something with the intercooler's efficiency. The meth lowers your combustion chamber temps during the process and that is what allows for more boost and timing to be used. If the kit is not tuned when installed than yes you could run into tuning issues. You really should use the 50/50 mix to get the most out of the kit. The water is a big factor in the cooling of the chamber.
Old Aug 19, 2006 | 05:23 PM
Double-L's Avatar
Well I heard that so I changed to a 50/50 mix, Water and alky just to make sure and my truck run like sh*t so I told the guy I got the kit off and he said who in the world told you to put water in it, Run it out and remember 100% alky NO WATER, What I wanted was to lower my combustion chamber temps so I could run more timing and have higher octane, Haven't upped my boost yet but at the same high timing turn the alky on the et drops but it does help me with the traction problem
Old Aug 19, 2006 | 09:35 PM
BigBlackAv's Avatar
to get around the 2 qt problem i am using the factory bottle ... it holds 5 qts!...and tells me in the DIC when it is low.
Mr. Chainsaw
Oct 18, 2015 08:00 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
old motorhead
Sep 29, 2015 08:22 PM
bagged7104SS
Sep 24, 2015 08:42 PM
