IAT sensor for after intercooler?
Old Jun 18, 2014 | 04:11 PM
Will's Avatar
Default IAT sensor for after intercooler?
Hey guys, since my IAT is in the MAF, what are you all using that will work with the factory wiring?
I know I will need to cut the two wires from the MAF to wire into it, but I see tons of different IAT sensors on Amazon. Some labeled open element and some closed element.
Part numbers would be cool too. I do know it needs to be a two wire.
Old Jun 18, 2014 | 04:35 PM
AkSSS's Avatar
This is the one that I used.
GM Open Element IAT Sensor with Pigtail DIYAutoTune.com
Old Jun 18, 2014 | 04:53 PM
Chevy_King1500's Avatar
^^ same one i have, works good
Old Jun 18, 2014 | 07:23 PM
Will's Avatar
Does it require tuning for sensor calibration? Thanks guys!!
Old Jun 18, 2014 | 08:31 PM
mdwatts11's Avatar
Curious about this as well. I know if you are going sd then you have to have this but if you simply want more accurate readings, can you just cut the wires from the maf that measure the temp and rewire them to this sensor and put it right before the throttle body?
Old Jun 18, 2014 | 09:41 PM
Will's Avatar
I am going SD, so I would really wanna know!
Old Jun 18, 2014 | 11:40 PM
AkSSS's Avatar
Nope. It works just like a factory sensor. Take the two wires off the maf and run them to the new sensor.
GMCtrk
Jan 27, 2016 06:47 PM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
TAPyvehc93
Sep 17, 2015 10:10 AM
sTNT971
Sep 11, 2015 02:38 AM
