I went and did it. Added an extra power adder
Old Aug 1, 2008 | 11:56 PM
hemidup's Avatar
Default I went and did it. Added an extra power adder
I just finished up adding a 2 Stage nitrous system on my truck. Both stages are 30 shots. I'm hoping to pick up a couple 10th's. How much of a gain have you guy's seen with adding a 50 or 75 shot?
Old Aug 2, 2008 | 12:12 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I dropped .5 with a 50 shot. If I can get everything to hang together I expect even better results with the 75. I lifted the fronts yesterday and actually chirped all 4.
Old Aug 2, 2008 | 07:26 AM
Superado's Avatar
11 Second Truck Club
you mean like this, right?
Old Aug 2, 2008 | 10:28 AM
trever1t's Avatar
uh, sure! Somthing like that....lol, rick was hanging on to the laptop and pressed into the passenger seat, Archie was in the back laughing as I tried tokeep it tracking straight down the street you're right, it was only 3 that could have chirped
Old Aug 2, 2008 | 10:47 AM
Raffman's Avatar
How are you guys adding nitrous. I've already got Meth but thinking of a little "shot". I was at the 1/8 th last nite and in this heat can't do any better than 8.5 because of 150+ degree IAT's
Old Aug 2, 2008 | 10:48 AM
trever1t's Avatar
wetshot into the intake tube.
Old Aug 2, 2008 | 11:01 AM
OUT2WIN's Avatar
So the nitrous is before the radix? Joejoe is wanting to add a little nitrous to his Joe Gibbs tahoe but thought you could't before the supercharger.
Old Aug 2, 2008 | 02:36 PM
Raffman's Avatar
Sooo wetshot meaning mixed with gas? Could I still run the meth too or not necessary?
Might not need this when the 370 goes in ,but it's never enough!
Old Aug 2, 2008 | 04:21 PM
hemidup's Avatar
Dropping .5 would work just fine. Did you pull any additional timing for your 50 shot?
Old Aug 2, 2008 | 07:52 PM
trever1t's Avatar
Yes, wet = gas is mixed with nitrous and injected into the intake.
I run both, meth is active all time, the n2o is for the track and too much for 'normal' street use
Not with the 50 shot. The 75 shot that I now have has a couple of * pulled but I still run 19+* with the meth.
