i a t temperatures
Old Sep 10, 2015 | 06:44 PM
  #31
TXsilverado's Avatar
just wanting to help control the heat pump...if I remember correctly it has 28gph of meth being injected behind the throttle body. the tune in it blows, so I've never logged long enough to see what the IAT does at WOT.
Old Sep 10, 2015 | 06:46 PM
  #32
Originally Posted by BlackGMC
Go drive it around let those IATs get into the 150* mark them open up the tank to see if it is really hot.
it is...the tank is in the back seat and it's a damn furnace back there.
Old Sep 10, 2015 | 06:51 PM
  #33
George C....'s Avatar
Formerly ScreamingL
Insulating your lines will help some
Insulate the tank it will help
Old Sep 10, 2015 | 06:54 PM
  #34
BlackGMC's Avatar
Resident Retard
I wonder if you pump/lines are hooked up correctly. The flow of fluid should go
Tank
Pump (which should be gravity feed bt tank, those pumps are pushers not suckers)
Heat exchanger up front of radiator
Supercharger
Tank
Old Sep 10, 2015 | 06:55 PM
  #35
BlackGMC's Avatar
Resident Retard
Also are you sure the pump is running?
Old Sep 10, 2015 | 07:18 PM
  #36
03chevytruck's Avatar
Quote:
Originally Posted by Show-n-go5.3 View Post
So,Tim, tell us about this intake tube set up thats drastically reducing ur IAT. I dont have any 1/4 mile data for u but im interested to see what u have set up.
Originally Posted by tim wellington
sent u a message
What about me?? lol
Old Sep 10, 2015 | 07:50 PM
  #37
Tank
Supercharger
Tank
i do plan to check the fluid flow direction. been messing with the s10 too much to even look at the Camaro.
as for the pump...it sounds like a water fall behind my seat when i key on. that pump moves a ton of fluid!
Old Sep 10, 2015 | 07:53 PM
  #38
BlackGMC's Avatar
Resident Retard
It might be moving tooo much. Meaning not staying in the heat exchangers long enough to cool anything. i wonder if those KB units act differently than a TVS.
Also if i remember correctly your IAT sensor is in the tube behind the TB?
Old Sep 10, 2015 | 07:58 PM
  #39
no I haven't found the IAT sensor yet. I believe it is below one of the runners somewhere. KB wants me to pay $50 for an install guide. **** them in their ***.
Old Sep 10, 2015 | 08:25 PM
  #40
^ That's CRAZY!... Oh you spend money on our products... Lets charge you for some literature....
