I stuck my hand in my J-Tube
Old May 3, 2006 | 07:05 PM
moregrip's Avatar
what a rush!
Default I stuck my hand in my J-Tube
to feel the inside texture. Now that there is a 90mm hole I can fit my whole hand in there. On the 180deg radius there was a noticable sharp ridge.
I just couldn't leave it alone so I started sanding......which lead to more sanding..........which lead to more sanding.........LOL.........now I'm in the middle of another project. I doubt I will polish the inside of the J-Tube but I will definitely knock down the peaks to promote better flow
Old May 3, 2006 | 07:18 PM
8ALTNG's Avatar
Only you would stick your hand in a J-tube to feel the "inside texture" You crack me up Grippy.
Old May 3, 2006 | 07:33 PM
03sierraslt's Avatar
Moregrip- What else were you sticking your hand into?
Old May 3, 2006 | 07:57 PM
TIM Z's Avatar
11 sec. Truck Mod
its always fun to have a new project but just dont look behind your door panels or between your bed and cab!!!
Old May 3, 2006 | 08:08 PM
dewmanshu's Avatar
Moderately Differentiated
LOL
Grippy I bet you get sidetracked during sex. "Oooh...ahhh...oooo...heeeey, you know with a little bit 200 grit I could probably do something with that small rough spot you got there hunny!"
Old May 3, 2006 | 08:11 PM
krambo's Avatar
I did the same thing. Use the mother's powerball for finishing with Al polish. i used a 3 stone honing device on the end of a drill to knock down the rough stuff. Worked well.
Old May 3, 2006 | 08:12 PM
TurboGibbs's Avatar
Originally Posted by dewmanshu
LOL
Holly ****! :jest
Old May 3, 2006 | 08:15 PM
moregrip's Avatar
what a rush!
this is my J-Tube
there are many like it
but this one is MINE!
Old May 3, 2006 | 08:22 PM
dewmanshu's Avatar
Sure it is. Put the J-Tube down and step away from the jar of vaseline Grip!
Old May 3, 2006 | 08:28 PM
bud8fan's Avatar
