I need more power!
Old May 23, 2006 | 04:41 PM
  #21
gao8302's Avatar
The meth kit it is. I tow a boat sometimes twice a year, do you think a stall is ok? If so how big of a stall.
Old May 23, 2006 | 04:44 PM
  #22
parish8's Avatar
single digit dreamer
how big of a boat? i towed 4000lb's thru the mountains with the yank3000 and didn't have any problems but if you have a really big boat you might want to go more mild. the 3000 is prety mild though.
Old May 23, 2006 | 04:48 PM
  #23
gao8302's Avatar
Its just a little bass boat. I dont do alot of towing in general. If im going to run more boost who make a good pulley that is cheaper than whipples .
  #24
FlaBouy's Avatar
Originally Posted by gao8302
I think you guys have me sold on the water/meth. But how long does it last driving around town hitting boost once and awhile. How much boost is ok to run on a stock 5.3? I would like to get as much out of this engine in bolt ons first and then step up to a full engine build. I thought about it all day. Back to meth setup, what is a good brand and does anyone have a part# on it? As far as bolt ons now what else is the best bang for your buck? Thanks alot guys for all the help.
Hehe, the question about how much boost on a stock bottom will probably light a firestorm...but for my .02 cents, I have been running 12 psi of boost on the stock bottom since September. I have been throwing 650 hp to the crank since February 22nd......My short block is stock with 49,000 miles on it, the last 3000 at 12 psi. I am getting good results with my meth kit. It is a stage 2 Snow Performance with the controller. I start spraying at 1 psi and go full spray at 10 psi.... Like Parrish says, depending on the heavinest of yout right foot you should see a couple tanks per gallon of meth. I mix mine from walmart. 1 gallon of winter washer fluid to 2 bottles of Heet. Cost about 3 bucks to make a gallon.....
Hope this helps....
Old May 23, 2006 | 04:49 PM
  #25
FlaBouy's Avatar
I tow a 22' Wellcraft fishing rig on my 2600 stall and tranny cooler....No problems....
Old May 23, 2006 | 04:51 PM
  #26
gao8302's Avatar
Washer fluid? What about all the detergents in the washer fluid? Is that ok?
  #27
FlaBouy's Avatar
Hehe.... keeps it nice and shiny......
Old May 23, 2006 | 04:54 PM
  #28
gao8302's Avatar
Flabouy i see you have a bbk 80mm TB is it really worth the $. I have thrown around getting on for some time now.
Old May 23, 2006 | 04:57 PM
  #29
FlaBouy's Avatar
For you maybe...for my centrifugal......it sounded good at the time......
Old May 23, 2006 | 04:58 PM
  #30
parish8's Avatar
i hated my bbk. it made the truck very dificult to drive. lungy. i think someone makes a larger tb that somehow flows more air when open all the way up but is progresive at part throttles so it doesn't get all jumpy.
