I need a little help swapping parts from one engine to another.
Old Feb 16, 2021 | 08:21 PM
crashmymax's Avatar
Originally Posted by arthursc2
What's the issue with the 5.7? Too much green paint?
LOL! It was a phase. Easy to spot oil leaks.
Old Feb 16, 2021 | 08:30 PM
arthursc2's Avatar
Easy to spot from space too!
But for real, with the heads off was anything obvious?
Old Feb 16, 2021 | 08:47 PM
crashmymax's Avatar
Unfortunately I don't know what to look for but I did not melt a piston. All the pistons look the same to me. I would think if there was a bad ring one of the pistons would look different. More carbon or something.
Old Feb 16, 2021 | 09:23 PM
arthursc2's Avatar
What shape was the cam in? Lifters?
edit: was this the motor you had a pressure issue with at first because the galley plug was left out by the shop?
Old Feb 16, 2021 | 09:30 PM
crashmymax's Avatar
I'm going to pull the cam tomorrow. If it's in good shape it will be going in the other engine along with the DOD delete kit and arp studs. I'm unsure what to do about springs since I can't remember what springs were used on the 5.7. I might just grab some cheap ls6 springs I think they will work with the triple 12 cam.
Old Feb 17, 2021 | 11:42 AM
crashmymax's Avatar
I think the cam is ok I am assuming these marks are normal wear?
Old Feb 17, 2021 | 11:48 AM
arthursc2's Avatar
I'd run it, looks great
Old Feb 17, 2021 | 12:52 PM
crashmymax's Avatar
If I decide to gap the rings can I pull each piston 1 at a time gap the rings and reinstall? Since I'd be reusing bearings there is no need to plastigauge correct? Just torque bolts and should be good.
Old Feb 17, 2021 | 01:20 PM
arthursc2's Avatar
maintain the rod cap orientation and you'll be fine. Dont break a ring or you'll be mad
Old Feb 17, 2021 | 07:34 PM
RedXray's Avatar
100% Redneck
I'd hit the cylinders with WD40 and a 240 grit ball hone then open the gap on a new ring set.
Be sure to clean the hone grit from the cylinders.
