I have a boosted dilema. opinions please
Yes. There are several different tables. The only code I am getting is P2101 saying that the blade is restricted. (Basically from.what I have gathered, the actual TPS does not match the desired TPS at the TAC module).
Not that it matters, but I don't exactly have a "warm fuzzy" feeling about an ebay DBW throttle body, especially when listed as "fits all". I'd be looking to borrow a known-good throttle body. One that has been proven on a PD blower already.
Sounds like the blade is trying to get sucked closed (ie restricted) soon as that happens the computer shuts it down. I've read good things about the nick Williams tb's. maybe that would help you out. They make from 90 to 102mm. Anytime the tb can't move or tries to close the computer with shut it down. Mine did this when I polished it and it had a slight drag to it. It felt fine to me but the computer didn't like it. After I aligned the blade better it was fine.
Hmmm. Gold blade should be LS3, this is what I have. ( opens opposite LS7 from what I recall, LS7/LS2 are same I believe) I have heard of this issue alot on truck throttle bodies but not the LS3. If you send me a copy of your tune I can look to see if I see anything. I had a 87mm truck TB that would act up similar on a TBSS I tuned.
I will get a copy of my tune posted up after work. I am going to run it tonight without my CAI and see if that helps. It might be directing the air in an angle causing that problem. If that is the case, I would think I could weld a divider in the middle of the pipe.
I've had good luck so far with my NW102 throttle body. Be advised that if you go up to the 102 you will have to port the inlet of the maggie or the TB blade will hit and send you into REP mode again
I also think Supersub has had good luck with the TPIS throttle body and even has a hookup for preported maggie front inlets.
. I also think Supersub has had good luck with the TPIS throttle body and even has a hookup for preported maggie front inlets.
Well I have had my truck for 3 years, and have been plagued with Reduced Engine Power. I have seen people run into this problem, and I have never seen anyone resolve it. I have everything in my sig. I am just at the point where I am maxing out my 2 bar. Whenever the boost gets high, it goes into REP. I have exhausted every possible solution that I know of to resolve the problem with no luck. I have talked to numerous people, any nobody has a resolution. I basically have a few options.
1. Get rid of the truck.
2. Try to switch to a cable TB (Many people say it can be done, but after a ton of looking I can't find anyone).
3. Switch to a turbo as I have never seen the P2101 problem when you are pushing air through the TB.
4. Find another option.
Any thoughts
Any thoughts
