that huge heat exchanger from frozen boost
Old 07-08-2010, 01:08 AM
I have a gauge for that
Atomic's Avatar
Default that huge heat exchanger from frozen boost
...got it installed
stock maggie one compared to the type 101 from frozen boost
I had to redo my mounting stuff for the hex and big trans cooler
I have 3 7" fans I still need to put on. I am going to put 2 on the heat exchanger and 1 on the trans cooler. The tranny cooler doesnt work nearly as well right there as it does normally...I also need to get an elbow fitting for the hose barb since its too tight over there, a couple more bolts, and wire up the fans.
I did a quick test of the new hex and cruising IAT is about the same as before +15-20), and peak temp is about the same (around 150), but recovery time is about twice as fast.
Old 07-08-2010, 01:20 AM
Baltimore Whore
Mangled03gmc's Avatar
Looks good man. You don't want that thing to get hot do ya??.. LOL Surprisingly enough frozen boost sells some really nice coolers
Old 07-08-2010, 05:15 AM
11 sec. Truck Mod
TIM Z's Avatar
Dayumm thats a big hex !
Nice install , your brackets look good.
What do you run for hex coolant? Do you use water wetter?
Old 07-08-2010, 09:08 AM
Atomic's Avatar
Its something like 80% water 20% antifreeze.
Old 07-08-2010, 09:42 AM
TX Tahoe Z71's Avatar
Very nice! That's the h/e I wish I would have picked up instead of the CTS-V one, that thing is huge.
My 20gpm Meziere i/c should be arriving in the mail today and should be on in a couple of weeks, so I will get some IAT's and recovery times for it and post up.
Old 07-08-2010, 11:34 AM
Performance Trucks Sponsor
FarmTruc's Avatar
I used to use that one on my kits, they work fine! Holds tons of fluid, only thing it's a little thick, but well worth the installation and fits behind the stock grill.
Old 07-08-2010, 12:13 PM
skipperdaddy's Avatar
what kind of coolant pump u gonna use?
Old 07-08-2010, 12:24 PM
Red04Silverado's Avatar
Glad this exchanger is working out. Ive been wanting it for awhile
Old 07-08-2010, 01:20 PM
Atomic's Avatar
Im using the stock maggie bosch pump.
Im a little disappointed that it didnt help the peak temps any since that is what I was really wanting, but it does help tremendously with recovery times.
Old 07-08-2010, 01:42 PM
Truck Sponsor
TrickTurbo's Avatar
Not supprised about the final numbers. The IC has alot more to do with that then teh HX. But you did notice a quicker drop after the fact meaning this HX holds more water and cools it better.
Looks like you had some room between the HX and the ac. Would your tranny cooler fit there.?
To bad your not closer I would like to try our new one. Probably 3 times larer then that one.
Nice install behind the grill.
Quick Reply: that huge heat exchanger from frozen boost
