How would my motor do with a turbo?
Old May 16, 2007 | 03:23 PM
14 Second Truck Club
Default How would my motor do with a turbo?
If I put some patriot stage 3 6.0 heads (72cc) on my 383 it would drop my compression down to around 10.1:1.
How much boost can be run safely with this set-up and 93 octane? (motor specs are in the sig) I would like to run a Turbnetic Ball Bearing TC-70 and at least 7-8lbs of boost. I figure that would be good for 550rwhp in my truck later down the road.
Old May 16, 2007 | 04:13 PM
nightrunner's Avatar
Mr. Obvious
you should be fine with your tune spot on
if im not mistaken the lq9 has a 10:1 compression and 2004SSS put i think about 15psi through one without meth
Old May 16, 2007 | 10:16 PM
Stoichiometric's Avatar
More boost will allow less timing, that is fine to a certain point. You should be able to run 7-8lbs, maybe more with meth.
TXsilverado
Nov 26, 2015 10:54 AM
kyle's v
Oct 4, 2015 12:37 PM
jmarkway
Jul 18, 2015 09:23 PM
black6spdz
Jul 16, 2015 01:32 AM
