How much timing are you running on pump gas?
#52
smokeshow- what's your comp. and do u run 100% meth?
I run 50/50 at 13# & 20 degrees of timing. One thing with prochargers are boost is linear with rpm and I've read the water has it's own benefits with the meth.If I remember correctly it helps cool the combustion chamber.
#55
I run 70/30 meth/water. My truck has never liked running %100 meth. A little water in the mix helps cooling better than full meth in my opinion.
I run 18.5 degrees of timing on 15psi at the track. 93 octane and the meth mix. A/F 11.2-11.5.
