How much timing are you running on pump gas?
#41
Bump for this thread...lets get the timing/boost/compression discussion going again. OP, ever get this truck back to the tuner to work out that rich problem?
I'm wondering what some of you guys like sureshot and scooter k do to get so much timing into your setups. I just went up to 15psi and even at 9° timing its still showing knock here and there. AFR is mid-10s, meth included.
#44
Okay, I'm looking at a datalog I did in efiLive, and for the parameter SPARKADV (Spark Advance for Cylinder #1) I'm seeing the Max value of 55 and Min of -1.0...what am I missing here? I thought SPARKADV showed total timing
*EDIT: After thinking about it for a while, and doing some reading 55 degrees of advance is fairly normal for these engines under certain circumstances, and I mistakenly thought the Max value would show timing at WOT, which obviously isn't the case.
Is there an easy way to see what total timing is at WOT from a datalog? Even looking at dashboard B in efiLive where it plots data over time isn't the clearest way to see what the numbers are.
#45
MASS seller approved
I can't make heads or tails of that dyno graph..
EDIT:
Ok, I studied a little harder...
That AFR is retarded. It comes in at 11.4 and just nose dives throughout the pull. It should be at 11.4 the whole time. It shows you at 9.4 at the top of your pull. There is probably enough raw fuel in your exhaust to start a fire in your tail pipe, fast and the furious style.
I've also never seen a dyno hp and tq cross at such a low rpm. In fact I thought it was always supposed to be at the 5,250rpm mark.
I don't understand why when you pulled fuel to lean it out you lost power. I'd think as fat as that thing is you'd pick up a ton of power going from low 9's to low 11's AFR.
Get that tranny in and get it back on the dyno for some tweaking. I'd almost be afraid of washing the cylinders with all that fuel. I know you said you haven't gone WOT since the dyno, just sayin...
EDIT:
433/490 on a mustang is no joke, can't wait to hear what it does when you get your trans in and can trust it past part throttle!
#46
Mod with training wheels
IATs are around 115 before meth, and like 85 after meth has done its work.
#50
Hmmm......I wonder if the amount of timing you're able to run has something to do with the nature of FI being used. What I mean is, with a turbo, you're slammed with all of that boost at once, whereas a procharger you're not. I even remember Blown06 saying that when he was running 14#'s of boost, his sweet spot was 20-21*'s of timing. I never see KR on any logs, and he said he didn't see any either. I don't know if this theory is right, just saying.
