How much psi would i get...??
Old Jan 17, 2010 | 04:57 PM
lablackbeast's Avatar
doesn't know what quit means
Originally Posted by zippy
At 10.5:1 you should be able to run 8psi without a problem. 10psi with carefull tuning and 93 octane minimum.
so will i have to go to like the 9s on compression so i can can run 15psi cause thats what i want to run..??
Old Jan 17, 2010 | 06:10 PM
zippy's Avatar
For 15psi on standard pump gas you'll want to get the compression down to around 10:1 or less. Will you be running meth or any special fuel?
Old Jan 17, 2010 | 11:33 PM
i will drop it to around 10:1 so i can run that much psi.... and i want to run meth
Old Jan 18, 2010 | 03:27 PM
so 10:1 or less compression to run 15psi right...?? and i would have to run meth right..??
Old Jan 23, 2010 | 07:23 PM
zippy's Avatar
Yes sir.
Old Jan 23, 2010 | 07:31 PM
what pulley will get me there without belt slipping...??
Old Jan 23, 2010 | 07:35 PM
SLOXCAB's Avatar
i vote you buy the cog set up
Old Jan 23, 2010 | 09:19 PM
how much is that and were can i find it at..?
Old Jan 23, 2010 | 09:33 PM
SLOXCAB's Avatar
Call procharger
Old Jan 23, 2010 | 09:48 PM
sure will
