How much boost to expect?
Old Apr 9, 2008 | 11:07 AM
BigCountryx's Avatar
Originally Posted by nightrunner
a 112HH is not any bigger than a MP112, it just has the high helix rotors and therefore is a bit more efficient
So what does better efficiency buy you? Just a quicker cool down, maybe a little more top end? Thought it may equate into margionally higher boost. Guess I will wait and see.
Old Apr 9, 2008 | 11:11 AM
Originally Posted by Sambo53
No belt slip at all as far as I can tell. So did I, but I do have long tubes, high flow cats and a free flowing muffler. Could be why the boost is lower.
I'm gonna be installiing LTs, deleting my cats and a cutout along with the blower. Guess I should be close to what you are seeing.
Old Apr 9, 2008 | 03:43 PM
nightrunner's Avatar
Mr. Obvious
while i have no actual experience with blowers and BlownChevy could probably answer this better but, everything i have read says that when comparing the MP112 to the MP112HH, the 112HH is more efficient and therefore makes less heat at the higher boost levels (smaller pulleys). technically i think it(compressor) can be spun faster if you could eliminate belt slip or put on a bigger crank pulley. you might get .5-1psi more of boost on a 2.7" pulley because its not completely out of breath as a 112 would be. also with the better efficiency, you should be able to run a bit more timing and less meth. it all boils down to, the 112HH will give you lower IATs than the 112.
Old Apr 9, 2008 | 05:54 PM
MagnaCharger Rep's Avatar
Banned
You should see about 8 1/2 to 9lbs.
Old Apr 9, 2008 | 08:31 PM
Now that would be very nice Hope you close.
Old Apr 10, 2008 | 06:39 PM
Mort's Avatar
Good going! Looking forward to results. Good luck with the install.
Texas5.3_1251
Mar 5, 2016 08:10 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
Justin87gn
Sep 10, 2015 12:06 PM
06murder
Sep 4, 2015 03:54 PM
