How much boost
I am doing a dyno tune sunday over at edge. I am going to use E-85 so maybe I wont have to worry about meth for awhile. I was think 12psi Iis what I wanted to shoot for but I think the injectors I was told would be good for 12psi will not be and will have to get some 60+ injectors.
If you gona run the 42 lbs injectors and E85, you will probably running out injector at about 7-8 psi and 6k rpm. I can only run my 4.8 to 5800 and 11 psi with E85 and the 42's injectors are done. E85 needs about 30% more fuel. I can get 14psi out of them at 6K on gas. That's with spraying Meth (-20* WWF).
