How much boost
Old Apr 25, 2008 | 02:02 PM
macs406's Avatar
Default How much boost
How much boost will my motor handle with my current setup in my sig. That is of course with the right tune. I am also at 4500 feet.
Old Apr 25, 2008 | 02:03 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
compression ratio?
Old Apr 26, 2008 | 12:42 AM
macs406's Avatar
I believe its 9.5 to 9.8to1
Old Apr 26, 2008 | 12:46 AM
thunderwagen's Avatar
How much are you running right now and how maxed out are your injectors?
Old Apr 26, 2008 | 01:39 AM
stock48's Avatar
9 Second Truck Club
Should handle 12psi safley, or so with the correct tune. If your truck was lighter it would take over 15psi with good fuel. You are going to need bigger injecters, and meth though.
Old Apr 26, 2008 | 11:21 AM
macs406's Avatar
I am doing a dyno tune sunday over at edge. I am going to use E-85 so maybe I wont have to worry about meth for awhile. I was think 12psi Iis what I wanted to shoot for but I think the injectors I was told would be good for 12psi will not be and will have to get some 60+ injectors.
Old Apr 26, 2008 | 12:26 PM
kbracing96's Avatar
If you gona run the 42 lbs injectors and E85, you will probably running out injector at about 7-8 psi and 6k rpm. I can only run my 4.8 to 5800 and 11 psi with E85 and the 42's injectors are done. E85 needs about 30% more fuel. I can get 14psi out of them at 6K on gas. That's with spraying Meth (-20* WWF).
Old Apr 26, 2008 | 10:41 PM
macs406's Avatar
Thanks kb. I was mostly concerned with how much the motor will handel before breaking pistons and blowing head gaskets.
Old Apr 26, 2008 | 10:47 PM
BlownChevy's Avatar
blownerator
25 Year Member
Ahh yes, My favorite FI section question. " Can someone please tell me how to blow up my motor"
Old Apr 26, 2008 | 10:48 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
well about 2 years ago the limit was ~8lbs........last year was 10.....now it's 12!
