How much boost with a 3.25 pulley?
Old Aug 6, 2005 | 01:15 PM
Last Call's Avatar
TOTM: January 2007
Default How much boost with a 3.25 pulley?
I have a 3.25 pulley on a 5.3l. When the truck is floored it 2nd gear, from 2500-5500 rpm, I'm only seeing around 7 lbs of boost, does that sound right? Right at 6000rpm I may see 8-8.5 lbs, I dont think Im seeing enough boost.
Old Aug 6, 2005 | 03:56 PM
therock's Avatar
Default I'm Only A Novice...
...when it comes to the Radix but I think it is about right. There are many factors to consider. It's summer and very hot out. I have heard terms of "Wash Through" with high flowing heads and exhausts. Again I am a beginner so...
From what I read here 8.0 - 8.5 is alot of boost without spraying? You may want to verify your gauge.
Old Aug 6, 2005 | 04:32 PM
Hawk179's Avatar
I would still consentrate on less boost and more tuning. Better for the heat.
Rick
Old Aug 6, 2005 | 05:58 PM
1SlowHoe's Avatar
Destroyer of Transmissions
That does sound right to me. I have the 3.4" pulley on my 5.3 and see about 6 pounds on top. I have a 3.25" that is going on the Radix when I get my dyno tune in a few weeks, I am hoping to see 9 pounds on top. When people say that size X pulley equals X pounds of boost, they mean at the very top end, around 6000 rpm. 8.5 @ 6000 rpm sounds correct for a 3.25" pulley
Old Aug 6, 2005 | 08:18 PM
KySilverado's Avatar
I saw 8-9 with 3.25 until cam install. Now only see 6.
Old Aug 7, 2005 | 08:44 AM
thunderwagen's Avatar
I lost a lb after headers and exhaust. On my LQ9 with a 3.3 pully I saw about 5 lbs. Now that I have the 3.0 I am seeing 7 - 7.5 lbs when the belt isnt slipping.
Old Aug 7, 2005 | 09:45 AM
TurboGibbs's Avatar
my 4.8 had a 3.7 stock and would pull 7 and peak @ 7.5. I now have a 3.25 and it peaks @11.5 with stock motor and no exhaust mods.
SlvrSierra4.8
Oct 1, 2015 09:39 PM
1slwgto
Oct 1, 2015 01:51 PM
2500ZL1
Sep 12, 2015 03:50 PM
Justin87gn
Sep 10, 2015 12:06 PM
06murder
Sep 4, 2015 03:54 PM
