how many vic jr. intakes are in here?
did you get a vic jr? heres some dyno graphs of mine..
Both runs are with my 370 with 2 valve relief flat top pistons, pulls are done in 2nd gear, converter is very loose as you can see in the graph that it finally come in around 44-4500 rpm
243 heads milled .030, 244/248 .612/.615 112 lsa, Vic Jr 1375 cfm 4150 Throttle body. Peak tq (316) is around 5700 rpm, I believe it would have made more if i would have taken it on to 71-7200 rpm.
241 heads-small port work, 230/226 .597/.56x 113 lsa, Prod Prod 85MM Intake and Throttle body. Peak tq (292) is around 5100 rpm and Hp peaked around 6000.
yes and it just got to RPM. going today to pick it up vic jr intake 1" spacer,mangafuel FPR,A1000 pump, wilson manfold elbow, i need a drive by wire TB. guess i am going to get one from GM or,, do yall have any ideas?
Pontiac Derek
09-19-2015 01:49 PM
