how far will 60lbs inj go
Old Jul 15, 2009 | 09:44 PM
05crew's Avatar
Default how far will 60lbs inj go
does anyone know how far a set of 60lbs inj will take you in rwhp? i am going to put the 408ci 88mm t-trim turbo on the dyno and i just dont know how far they will go? i guess i just need to go to the 79lbs,,
Old Jul 15, 2009 | 11:36 PM
zippy's Avatar
With meth we've made over 800 to the wheels with 60's and had AFR into the 10's until we leaned it out a bit. That is on a 416 with a pair of 60's in a Corvette. How far you run them will really very on whether or not you run a fuel pressure regulator where the pressure rises with boost. On the Corvette as an example we have a second pump that kicks on at 3psi and raises the fuel pressure to 63psi. We still have more room yet since we don't have the boost referrenced regulator hooked up to boost yet.
Old Jul 16, 2009 | 10:22 AM
05crew's Avatar
thanks for the help
Old Jul 16, 2009 | 12:01 PM
FarmTruc's Avatar
Performance Trucks Sponsor
The key is a good fuel system.
Over 821hp here in the 'ol farmtruc, twin 76's, non intercooled, but...
A1000, -10 lines, good fuel rails with 60's., no meth at 13psi.
So, yes, those injectors will be fine, just make sure the fuel system is capable.
With the setup you're planning, you can't build too big of a fuel system, go big!
good luck,
allen
Old Jul 16, 2009 | 01:46 PM
05crew's Avatar
how loud is that A-1000? i think im going to do return fuel with tow 340 intanks and -8 feeding and -6 return...with a boost ref reg. will that work
Old Jul 16, 2009 | 02:31 PM
05GTO6SPEED's Avatar
you need bigger ones so you can sell me the 60s cheap hehe
Old Jul 16, 2009 | 03:16 PM
TrickTurbo's Avatar
Truck Sponsor
Get with Aeromotive on the set up. I would run the same size return or larger then the pressure line.
Old Jul 16, 2009 | 10:12 PM
05crew's Avatar
drove the truck tonight for a little bit...that 88mm is loud as hell..i hope its getting good oil...im using the same oil line i got from you trick. and a -10 oil return
Old Jul 16, 2009 | 10:21 PM
FarmTruc's Avatar
that's plenty of feed line and more than enough drain line, so that's good, unless it's plugged lol.
a -6 is ok for the fuel return, I run a -8...
Old Jul 17, 2009 | 01:46 PM
TrickTurbo's Avatar
Truck Sponsor
-3 is plenty large for a feed line. Might take it off at the turbo and do a quick start making sure no trash as gotten into the line while swapping turbos out.
Or just pull your return line off at the pan start the truck and catch the oil as its draining. I like this one better less chances of making a mess.
With NO oil at the turbo and driving it, it would have smoked the turbo unit for sure.
bisqikss
Sep 27, 2015 09:40 PM
OHsixLS3
Sep 25, 2015 11:20 AM
97_ek
Sep 23, 2015 09:16 PM
chevstang421
Sep 10, 2015 09:16 AM
