How far can i push it???
Old Jun 25, 2006 | 02:03 PM
macs406's Avatar
Default How far can i push it???
I have already lost one motor by to much boost and not enough fuel. Now that I have lowered the compression to 8.7 or so and had the motor balanced I am curious how far I can push it. I plan on adding alkycontrol and maybe some NOS gor out of the hole. I have also added a Dynojet WB, I also have bought SCT tunning software so I can get the AFR right on 11.5-11.8. I was hoping to get 18-20lbs, possible? I guess I should be asking Parish all the ?'s.
Old Jun 25, 2006 | 02:07 PM
bud8fan's Avatar
just get your tuning right and you shouldnt have any problems...
Old Jun 25, 2006 | 02:29 PM
greentahoe's Avatar
I dont see you being able to come near 18-20# on the street with a GT67 and 6.0. Trying to push that much out of that combo is going to be nothing of problems. Is the motor forged? Im going to start out with a 6.0 and GT67 until I get the 370 built. Then when I get to it I'll swap in the 370 and go with a GTS76 or something along those lines
Old Jun 25, 2006 | 02:44 PM
macs406's Avatar
How could I push it?? Everything is stock except for the diamond forged pistons and it was balanced. In september if the price is right i am going for the 481 setup with an ATS built trans.
Old Jun 25, 2006 | 02:55 PM
greentahoe's Avatar
if you have forged pistons and good rods you should be set as long as the tune is good. The GT67 is good for you since it will make full boost lower. What size converter and gears are you using? If you want to make 18-20 you will be very near uncharted water. I believe only Parish and 2Tone have pushed it that far. Parish was using a megasquirt system and HUGE injectors.
Old Jun 25, 2006 | 03:22 PM
macs406's Avatar
No convertor yet with 5:13 gears and now 40"tires with 22" rims. So 15-16 is more feasible? I plan on smoking this motor once more but I want it to last the rest of the summer.
What are the good upgrades for a 4L80 with out disassembling it-convertor, valve body, solenoids....
Old Jun 25, 2006 | 03:34 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
You don't have enough injector for 18-20psi. 42lbers will take you to 480 crankshaft hp assuming an 80% duty cycle, 58psi of fuel pressure, and using a BSFC of .65. That's about 10-12psi on 364 cubes.
To get to 18-20psi you need big injectors -- I run 75 lbers (rated @43.5psi) with two fuel pumps, a boost ref'd (1:1) fpr and meth. I believe Jim runs 96lbers. In either case you need a peak and hold injector driver (either a fly board on an MS or a stand alone acceleronics like I run).
Old Jun 25, 2006 | 03:37 PM
greentahoe's Avatar
wouldnt he be OK at say 15-17 with the meth kit, 60lb injectors and an inline? That would be ALOT of power with a good tune and a little larger turbo.
Old Jun 25, 2006 | 04:01 PM
macs406's Avatar
so with my current setup what are my limits? How much power can i make?? I am new to the car turbo scene, I have had turboed sleds for awhile now.
Old Jun 25, 2006 | 07:08 PM
jblack6527's Avatar
just an educated guess, i could be way wrong, I would say a good safe boost would be about 12-14, then if that works out fine, maybe jump up to 15-16 later.
