How Do You Boosted Guys Run Your PCV System?????
Old Apr 22, 2008 | 10:47 AM
Default How Do You Boosted Guys Run Your PCV System?????
Just Woundering How Everyone Mods The Pcv System On Their Trucks, I Have A 05 Serria Denali 70mm Front Mount Turbo Just Came Together The Other Night, Got It Out For A Shake Down Run And Is Burning Oil Under Decel, That When I Took A Closer Look At The Pcv System And Saw The Design Was The Cause. Still Want To Run Some Type Of Pcv System Of Oil Control.
Any Ideas???
Old Apr 22, 2008 | 11:06 AM
thunder550's Avatar
High on diesel fumes
I'm running a hybrid PCV/breather. I have an LS6 valley cover with a check valve that routes to the large vacuum port on top of the intake manifold. I have another line that runs from the passenger valve cover to a fitting just in front of the turbo, then I have a breather on the rear port of the driver's side manifold.
Old Apr 22, 2008 | 11:14 AM
WHAT DO YOU MEAN BY A HYBRID/PCV BREATHER??
Old Apr 22, 2008 | 11:16 AM
thunder550's Avatar
.....that I have a PCV system and a breather.....
Old Apr 22, 2008 | 11:26 AM
AHH I SEE, THANKS, THAT WAS WHAT I WAS PLANING ANYWAYS BUT WANTED TO KNOW IF THERE WAS SOME REALLY CLEAN FACTORY WAY OF DOING IT WITH OUT A BREATHER, THANKS, ILL PROBLY DO THAT CAUSE ITS QUICK AND EASY
Old Apr 22, 2008 | 11:28 AM
thunder550's Avatar
You can try it without a breather if you want, I'm not sure i need it but I've been having oil burning problems so I wanted to make sure I didn't have an crankcase pressure problems.
Old Apr 22, 2008 | 11:41 AM
IM ACTUALLY CONSIDERING RUNNING A VACUUM PUMP WITH A BREATHER TANK, THAT WOULD SOLVE EVERYTHING
Old Apr 22, 2008 | 12:19 PM
t_thall's Avatar
I have been running a catch can and a belt driven vacuum pump from a 6.5 turbo diesel. It completely cured all my smoking problems but it is noisy and doesn't like the high rpm's. Im gonna try taking it off and try an oil line restricter in the turbo feed line and catch can with a breather again and see what happens.
Old Apr 22, 2008 | 12:26 PM
CurtD's Avatar
10 Second Truck Club
You could try something like in the link. I am doing it when i collect all of the parts http://www.turbobuick.com/forums/gen...-pump-how.html
Chris where did you get the check valve you are using?
Old Apr 22, 2008 | 12:44 PM
THE LT1 SETUP IS A GOOD IDEA BUT REALLY UGLY AND SEEMS MORE INVOLVED THEN IT HAS TO BE, GOOD IDEA THOUGH, POOR MANS VACUUM PUMP
