how did everyone route their oil lines
Old Oct 6, 2009 | 08:04 PM
LsxCody's Avatar
Default how did everyone route their oil lines
Just got my oil lines and fittings in. Anybody wanna go into detail on how to do it. Oh and I got everything from KB. thanks
Old Oct 6, 2009 | 09:14 PM
LsxCody's Avatar
Any help
Old Oct 6, 2009 | 09:19 PM
nonnieselman's Avatar
i routed the feed line under the intake manifold on Lownslo's front mount to the turbo... then the drian keep it straight as possible and i drilled and tapped the pan for a 3/4" fitting.
Old Oct 6, 2009 | 09:20 PM
not hard at all, just keep the hoses away from the exhaust or any moving parts
Old Oct 6, 2009 | 09:59 PM
LsxCody's Avatar
The rubber hose kb sent is the drain right. Also did u tap the passenger side of the pan for the return
Old Oct 6, 2009 | 10:12 PM
not sure whats in his kit.... but yea tap the passengerside of the pan
Old Oct 6, 2009 | 10:14 PM
kbracing96's Avatar
Sorry i didn't get back to your PM yesterday, I'm SUPER swamped right now... :o/ The feed is 1/8npt tapped into the fitting above the oil filter, then I run the line up the back of the motor and down the the pass side of the intake over to the turbo. The 1/8npt 90* street-L fitting screws into the turbo, then the -4 fitting on to it then the -4 SS hose to it.
For the drain, the 2 bolt flange bolts to the turbo then the extension pipe screws into, then the 1/2 NPT coupler, then the 1/2NPT barbed fitting. The rubber hose pushes on to it then routed down to the barbed fitting that you will need to drill and tap into the side of the oil pan. Here is the pic I sent you where I put in on my truck. HTH
Old Oct 6, 2009 | 10:55 PM
LsxCody's Avatar
Thanks man
GXPJAY
Feb 13, 2022 08:15 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
Mzay
Jul 6, 2015 11:03 PM
Nimoryan
Jul 5, 2015 03:50 PM
