Holy 13psi
Old Mar 18, 2009 | 10:32 PM
2ktransam's Avatar
Default Holy 13psi
I swapped out my wastegate spring from a 5.5 to a 7.2 to run a little more boost on my low setting and I found two things. 1st I thought my turbo was maxed at 12psi but it was the weak spring not allowing my boost controller to go any higher. 2nd I think my meth system is clogged up because I am at 96% IDC at 13.5psi with the 60lbs. I can see in my tune that the meth is spraying but it's deffinitely not putting out the 1100cc/min that it should be. Anyway, this thing pulls like a freight trane now and is a blast to drive. I'm going to the dyno Friday as long as I can get my meth to work right and see what it's putting down. Wish me luck. LOL
Old Mar 19, 2009 | 12:27 AM
Dragframe's Avatar
9 Second Club
haha hells yes!! Sounds like fun... Miss my car
Old Mar 19, 2009 | 05:20 PM
UBLUZIN03's Avatar
Sounds like fun! I need to get my kit on....What dyno you going to?
Old Mar 19, 2009 | 05:23 PM
nonnieselman's Avatar
if i ran around on 8# boost all the time i would get in trouble.. haha and i thought 6# was fun...
Old Mar 19, 2009 | 05:54 PM
1BADAZZSS's Avatar
Its just a **** away
Old Mar 19, 2009 | 06:10 PM
its the flip of a switch away actually
22hp and 40tq more with very low timing and pig rich compared to 6#
Old Mar 19, 2009 | 06:11 PM
KySilverado's Avatar
Wish I could pump 13psi :sad:
Old Mar 19, 2009 | 09:05 PM
kbracing96's Avatar
I think your out of fuel pump,
Old Mar 19, 2009 | 09:11 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
If that's the stock pump, I know you are
Old Mar 19, 2009 | 09:56 PM
2ktransam's Avatar
I have a 255 in which I thought would be fine with the meth but the meth wasn't working right. I tested my meth kit today and the controller wasn't coming all the way on. I think it is good now but we will see tomorrow.
Are you running a single of double pump setup in yours Kyle?
