Holy 13psi
Old Mar 19, 2009 | 10:00 PM
2ktransam's Avatar
Originally Posted by UBLUZIN03
Sounds like fun! I need to get my kit on....What dyno you going to?
I'm going to Barry's up here near Lancaster. Hopefully everything stays together.
Old Mar 19, 2009 | 10:04 PM
kbracing96's Avatar
Originally Posted by 2ktransam
I have a 255 in which I thought would be fine with the meth but the meth wasn't working right. I tested my meth kit today and the controller wasn't coming all the way on. I think it is good now but we will see tomorrow.
Are you running a single of double pump setup in yours Kyle?
I have a single 255 intank and I KNOW it won't supply 60's at those DC's, I've been there with E85. Kept adding to the VE table and DC's went up, but AFR wouldn't go down. I'm adding a 255 inline I have for now till I can do 2 new 255's intanks.
Old Mar 19, 2009 | 10:15 PM
2ktransam's Avatar
Maybe it's time to add a third meth nozzel.
Old Mar 19, 2009 | 10:17 PM
nonnieselman's Avatar
Hope the meth pump dont die...
Old Mar 19, 2009 | 10:24 PM
2ktransam's Avatar
I keep my eyes glued to the wideband at all time. I think I'm going to invest in the safeinjection from Snow now that they brought it back out. It will turn off my boost controller if the pump ever loses pressure. Seems like it would be well worth the $300 price tag. You can even hook a gauge to it and it will show the flow rate through the nozzels.
Old Mar 19, 2009 | 10:35 PM
kbracing96's Avatar
I have a pressure switch set up so that unless there is actual pressure in my meth line, it won't switch to high boost.
Old Mar 19, 2009 | 10:47 PM
2ktransam's Avatar
Where did you get that setup?
Old Mar 19, 2009 | 11:06 PM
kbracing96's Avatar
I made it, just a pressure switch from McMaster-Carr in the meth line, and for my boost controller, I just have a manual one from ebay with a solenoid valve with a switch in the cab to control flow to the back side of the WG. Power has to go through the pressure switch to get to the noid to open the valve that allows flow the to back of the WG. Simple and works.
Old Mar 20, 2009 | 08:12 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Great idea!
Old Mar 20, 2009 | 09:49 AM
Rick_Vor's Avatar
Looks Like KB just added another project to my wish list.
Great Idea.
Thanks, Rick
