High temperature test
Old Jun 16, 2006 | 10:23 PM
MikeGyver's Avatar
Default High temperature test
I can just about tell the outdoor temp by adding 10 or 11° to my IAT, after the truck is fully warmed, at cruising speeds. It was 91° today, and I was cruising at 102°. Last year at similar temps, I was cruising at 172°. The biggest difference is this year, the temp only goes up 11° at most after a WOT run. Last year, they were going up 40°. It runs quite a bit better at 111° then at 212°. Still some KR. It needs more tuning.
OK, Linda, your turn, get it running.
Old Jun 17, 2006 | 10:00 AM
03sierraslt's Avatar
Those are some sweet IAT's, I am anxious to get my intercooler on to see what mine will be. Being that my intercooler is very similar to VBonds my IAT's should be close to his. A bit lower being that I am not running as small of a pulley as him.
Old Jun 17, 2006 | 10:30 AM
F8L Z71's Avatar
Very sweet! This is on 7psi?
Old Jun 17, 2006 | 11:53 AM
MikeGyver's Avatar
Yup. Dreaming of 11, I have the pulley for it, but I think I need more intake air and bigger injectors.
Old Jun 17, 2006 | 11:34 PM
Whippled 496's Avatar
Sweet! I was at Six flags today....so tomorrow will be spent gettin the truck done. I will post up with updates as soon as i got'em.
Old Jun 20, 2006 | 12:20 AM
At 91 ambient you numbers are much better than mine. its likely because I have ran the tubing right in front of the fan and it is more suceptable to heat soak plus you have a larger IC. With the fan on, Im about 20 to 30 over, so I will try using some heat wrap.
Old Jun 20, 2006 | 03:51 PM
MikeGyver's Avatar
What kind of heat wrap?
Old Jun 20, 2006 | 09:30 PM
I have the 2inch exhaust wrap from this website. Wrap the pipe from the IC to the intake only.
http://www.designengineering.com/products.asp
Texas5.3_1251
Mar 5, 2016 08:10 PM
01silvy
Sep 26, 2015 10:20 PM
sTNT971
Sep 26, 2015 06:27 AM
jfuegner
Sep 22, 2015 12:30 PM
Go5.3tt06
Sep 14, 2015 02:11 PM
