high ltrims
Old Sep 24, 2012 | 09:44 PM
black04's Avatar
the filters are letting in unmetered air thats not measured by the maf.
Old Sep 24, 2012 | 10:11 PM
black00chev's Avatar
Slowest turbo build ever!
It can be filtered on the passenger side, but not the driver side correct?
Old Sep 25, 2012 | 04:51 AM
blue0453's Avatar
What do you recommend.
Old Sep 25, 2012 | 05:33 AM
03sierraslt's Avatar
Filters on the valve covers does not mean its letting in unmetered air, are you pulling any vacuum on the crankcase at all? Make sure you don't have any open vacuum ports on the intake.
Old Sep 25, 2012 | 09:03 AM
black04's Avatar
I'm not sure same issue i ran into when i had a maf tune. Has it been doing it since you put the turbo on?
Old Sep 25, 2012 | 11:24 AM
blue0453's Avatar
Probally. I know for a fact since I changed injectors about a year ago. I wanna ditch the maf and go SD.
Old Sep 25, 2012 | 11:27 AM
blue0453's Avatar
How do I know if its pulling vacuum on the crankcase. The truck idles at around -17 if that's what you mean.
Old Sep 25, 2012 | 01:02 PM
Do you have any vacuum lines running from anywhere on the intake to anywhere on the motor as in to valve cover, valley cover etc?
Old Sep 25, 2012 | 02:43 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Have you tested your fuel pressure to make sure the pump isn't weak?
Old Sep 25, 2012 | 03:07 PM
Good point, this too.
