high ltrims
#22
Bringing this back as I am still chasing the problem. I have swapped the mafs with a buddy reset ltrims and they climb right back up to +25. Today we put the smoker on the truck and found one small leak on the manifold took care of that and still no change. Any other ideas, o2s seem to be working properly switching back and fourth.
#24
#27
I chased this around untill I went 2 bar SD, my setup had a tight bend infront of the MAF. I think that was causing it to mis read the air it was too turbulent maybe. I could not get it to work but once I "failed" the MAF all seemed right. I am working on the SD tune now but all is better in my world on that end anyway.
Dave
Dave
#28
Ok update. Fuel pressure is good, reset fuel trims climbed right back to 25. Something I notice though is when you tap the gas the ltrims will drop drastically. Then when you let off right back up.
